Managing NSE 3000 using cnMaestro
NSE 3000 is managed using the cloud-hosted cnMaestro (a management solution from Cambium Networks).
This section covers the following topics:
Claiming an NSE 3000 device associated with a site
A device manufacturer serial number (MSN) is required to claim an NSE 3000 device. You can find the device MSN at the bottom of the device as shown in Figure 1.
Figure 1 MSN of the NSE 3000 device
To claim an NSE 3000 device that is associated with a site, complete the following steps:
  1. From the home page, navigate to Monitor and Manage.
    The System page appears, as shown in Figure 2.
    Figure 2 The System page
  2. On the left panel, in the Networks section, expand the site panel.
  3. Click theactions () icon and select Claim Device(s).
    The Claim Enterprise Devices window appears, as shown in Figure 3.
    Figure 3 The Claim Enterprise Devices window
  4. From the NSE Group drop-down list, select the required group.
    Note
    The selected NSE group is automatically pushed to the device while onboarding.
  5. In the Enter field, enter the MSN of the NSE 3000 device.
  6. Click Claim Devices.
    The NSE 3000 device that is associated with a site is claimed successfully.
High availability support for NSE 3000
The high availability (HA) support allows two NSE 3000 devices to share health information when connected through a LAN port (Port-6). When the devices are connected as an HA pair, one is configured as Primary and the other as Spare. The Spare device serves as a backup in case of hardware failures.
If the Primary device goes down, the Spare device becomes active. When the Primary device is restored, it regains its active state and the Spare device reverts to a backup state.
Note
The HA support is available from NSE release version 1.7 and higher.
Licensing
An NSE 3000 device requires a Tier-30 license to onboard to cnMaestro.
An HA pair (Primary - Spare) requires only one Tier-30 license. The Spare device does not require an additional license as it inherits the license from the Primary device.
On the expiry of the license, the device management is deactivated using cnMaestro. However, the devices are not deleted from the device list in cnMaestro.
Constraints on NSE 3000 devices
The following are the constraints on NSE 3000 devices in cnMaestro:
Creating an HA pair in cnMaestro
You can create an HA pair using either of the following options:
The HA pair configuration involves the following tasks:
Onboarding an NSE 3000 device as an HA spare
The primary device onboards as a standalone device to cnMaestro. An additional NSE 3000 device can be brought into the onboarding queue (without Tier-30 license) either by bulk claim (on the Onboard page) or using cambium-id and password. An HA pair is formed using the Onboard as HA spare option from the Approve Device window.
Note
  • The primary device must have the firmware that supports HA functionality.
  • The spare device must have the same firmware as the primary device. Otherwise, the system automatically upgrades the firmware of the spare device to match with the primary device.
  • The spare device must have the same model as the primary device. NSE 3000 device can be paired only with an NSE 3000 device model. It cannot be paired with an NSE 5000 device model.
When onboarding an NSE 3000 device as a spare, the device automatically inherits the NSE group of the primary device. This holds good even if the devices are claimed at the site level. Additionally, any change in the NSE group of the primary device is automatically reflected in the spare device.
To onboard an NSE 3000 device as a spare device, complete the following steps:
  1. From the home page, click the Onboard () icon.
    The Onboard page appears.
    Figure 4 The Onboard page
  2. Click the approve device () icon of the NSE 3000 device.
    The Approve Device window appears with the Onboard as HA spare option and shows all sites that have only one NSE device (as shown in Figure 5).
    Figure 5 The Approve Device window
Note
The spare device has the same NSE group as that of the primary device.
  1. Click Save and Approve from the Approve Device window (as shown in Figure 5).
    The spare device is onboarded (as shown in Figure 6) without an additional Tier-30 license.
    Figure 6 Spare device onboarded
  1. Click on the spare device name.
    You can see the spare device under a site (as shown in Figure 7). You can view the HA details in the Details section of the dashboard (as shown in Figure 7).
    Figure 7 Details about HA for the Spare device
Note
When HA is configured on Port-6 of the mapped device, you cannot edit the Port-6 configuration. A message is displayed on the Edit Port-6 window (as shown in Figure 8).
Figure 8 The Edit Port-6 window
Note
The fields in the Approve Device window (as shown in Figure 5) can also be configured using the Edit Device () icon from the Onboard page.
Claiming an NSE 3000 device as an HA spare
An NSE 3000 HA pair can be additionally formed using the Claim Device(s) option at the site level. When a second NSE 3000 device is claimed (assuming the primary already exists under the site), you have the option to claim it as a spare. However, claiming a second NSE 3000 device under the same site as a regular device is restricted.
To claim an NSE 3000 device as an HA spare, complete the following steps:
  1. From the home page, click the Monitor and Manage () icon.
    The System page appears.
  3. Click the actions () icon and select Claim Device(s).
    The Claim Enterprise Devices window appears.
  4. In the Enter field, enter the MSN of the NSE 3000 device.
    Note
    You can find the device MSN at the bottom of the NSE 3000 device.
  5. Click Claim Devices.
    Figure 9 The Claim Enterprise Devices window
  6. Click Yes.
    Figure 10 The Claim Enterprise Devices window
  7. Click Close.
    The device is claimed as an HA spare.
    Figure 11 Device claimed as an HA spare
The () icon indicates the primary NSE 3000 device. The ( ) icon indicates the spare NSE 3000 device.
When you click No in the Claim Enterprise Devices window (as shown in Figure 9), the Claim Enterprise Devices window appears (as shown in Figure 12). You cannot claim the device as an HA spare.
Figure 12 The Claim Enterprise Devices window
Moving the HA pair (in the tree)
The NSE 3000 HA pair can be moved as a single unit only. This can be done by changing the Network and Site for the primary device. The devices in the pair cannot be moved individually. Moreover, the NSE 3000 device or HA pair can only be moved to a site that has no NSE 3000 devices. Moving to a network is not allowed.
Note
An HA pair of NSE 3000 devices shares the same NSE group. Consequently, the NSE group selection for the spare device is disabled.
Deleting an NSE 3000 device from the HA pair
If one of the NSE 3000 devices in a pair is deleted, the other NSE 3000 device becomes standalone.
Deprecation of device overrides
The device overrides are removed from the Onboard page. The bulk overrides cannot be done for NSE 3000 devices.
When HA is enabled in the NSE group, the device overrides in the device context are hidden.
Figure 13 Device overrides are not applied when HA is enabled
When HA is disabled in the NSE group, the deprecated icon () is shown. Device overrides are being deprecated for NSE devices in the 5.1.1 version. When you hover the cursor over the deprecated () icon, a message about the deprecation is displayed (as shown in Figure 14).
Figure 14 A deprecation message
Upgrading the firmware
When you upgrade the firmware on the primary device, the firmware on the spare device is automatically upgraded. This ensures that both primary and spare devices run the same version.
Note
The Software Update tab is available only for the primary device.
Viewing aggregated data of HA pair
In an HA pair, the active NSE 3000 device shows the aggregated data for the pair. In the spare NSE 3000 device, a banner provides a link to the active device's page (as shown in Figure 15) to view the aggregated data. The same banner is displayed under the Security > Threats, Security > Vulnerabilities, and Clients > Local tabs.
Figure 15 Banner
Note
  • If the active device is offline, the aggregated data is not shown.
Creating Wireguard clients for NSE HA pair
When adding Wireguard clients from the VPN page, only the primary device is listed in the Device drop-down list (as shown in Figure 16).
Figure 16 The Add New User window -Wireguard
Configuring NSE 3000
To configure NSE 3000 devices, create configuration profiles called NSE Groups.
To create and configure a new NSE 3000 group, navigate to Configuration > NSE Groups and click Add New.
Figure 17 Creating NSE groups
For a new NSE group, you must configure parameters using the following tabs:
Basic
Using the Basic tab, you can configure basic group information, such as group name and group scope. You have the option to enable automatic synchronization of the configuration changes for devices associated with the NSE group.
To configure parameters on the Basic Information page, complete the following steps:
  1. Navigate to Configuration > NSE Groups and click Add New
    The Basic Information page appears, as shown in Figure 18.
    Figure 18 The Basic Information page
  2. Configure the parameters, as described in Table 1.
    Table 1 Parameters on the Basic Information page
    Parameter
    Description
    Name
    Name for the NSE group.
    This parameter allows a maximum of 64 characters.
    This is a mandatory parameter.
    Scope
    Scope determines the availability of the NSE group across different tenant accounts.
    By default, the following options are supported:
    • Shared - Configured NSE group will be available to other tenant accounts.
    • Basic Infrastructure - Configured NSE group will be available only to the Basic Infrastructure user. Other tenant accounts will not have access to the NSE group.
    Auto Sync
    Specifies whether the configuration changes made to the NSE group are automatically applied to all devices associated with the group.
    By default, auto sync is enabled.
    Enable HA
    Enables or disables the HA.
    By default, this parameter is disabled.
    Note:
    When this parameter is enabled, you must configure the IP Address (HA Spare) parameter by selecting the Static option from the IP Address Assignment drop-down list in the WAN Configurations section of the WAN screen (as shown in Figure 19).
Figure 19 The WAN Configurations section
  1. Click Save.
Management
Using the Management tab, you can configure the profile-related parameters such as time settings and event logging.
To configure parameters on the Management page, complete the following steps:
  1. On the NSE Groups > Add New page, select the Management tab.
    The Management page appears, as shown in Figure 20.
    Figure 20 The Management page
  2. Configure the parameters, as described in Table 2.
    Table 2 Parameters on the Management page
    Parameter
    Description
    On the Management page, there are Management, Time Settings, and Event Logging sections.
    Management
    Admin Password
    The password used to authenticate the NSE 3000 users who access through SSH or web.
    This parameter allows a maximum of 32 characters.
    Note: Click the editicon to reset the password.
    Time Settings
    Time Zone
    The time zone based on the installation location of the device.
    Select an appropriate time zone from the drop-down list to ensure that the device clock is synchronized with the wall clock time.
    NTP Server 1
    The IPv4 address or domain name of the primary Network Time Protocol (NTP) server.
    NTP Server 2
    The IPv4 address or domain name of the secondary or a backup NTP server.
    Event Logging
    Syslog Server 1
    The IPv4 address or the domain name of the syslog server 1.
    Port
    The port number of the syslog server 1 to which the syslog messages are sent.
    Supported value: 1 to 65535.
    Syslog Server 2
    The IPv4 address or the domain name of the syslog server 2.
    Port
    The port number of the syslog server 2 to which the syslog messages are sent.
    Syslog Severity
    The logs with the selected severity level that must be forwarded to the server.
    The following options are supported:
    • Emergency (Level 0)
    • Alert (Level 1)
    • Critical (Level 2)
    • Error (Level 3)
    • Warning (Level 4)
    • Notice (Level 5)
    • Info (Level 6)
    • Debug (Level 7)
  3. Click Save.
Network
Using the Network tab, you can configure LAN ports, VLANs, and static routes.
To configure parameters on the Network page, complete the following steps:
  1. On the NSE Groups > Add New page, select the Network tab.
    The Network page appears, as shown in Figure 21.
    Figure 21 The Network page
  2. Configure the parameters, as described in Table 3.
    Table 3 Parameters on the Network page
    Parameter
    Description
    On the Network page, there are DHCP Server, LAN Ports, VLANs, and Static Routes sections.
    DHCP Server
    DHCP Authoritative
    Indicates that the DHCP server is the primary and trusted source for IP address assignments in the network.
    This parameter is enabled by default.
    LAN Ports
    Click the edit icon to modify the configuration of the corresponding LAN port as shown in Figure 22, and click Update to apply the changes.
    Name
    Name of the LAN port.
    This parameter cannot be modified.
    Mode
    The VLAN mode of the port.
    • Access Single VLAN: An access port which places all traffic on its configured VLAN and only passes untagged traffic.
    • Trunk Multiple VLANs: A trunk port which allows the selected port to accept or pass 802.1Q tagged traffic.
    Description
    A brief description of the LAN port.
    VLAN
    This parameter is applicable only when the Mode parameter is set to Access Single VLAN.
    By default, VLAN value is 1.
    VLAN value can be in the range: 1 to 4094
    Native VLAN
    Indicates that the traffic on the native VLAN is untagged. This parameter is applicable only when the Mode parameter is set to Trunk Multiple VLANs.
    The Native VLAN value can be in the range: 1 to 4094
    Tag the native VLAN
    This parameter is applicable only when the Mode parameter is set to Trunk Multiple VLANs. When the Tag the native VLAN parameter is enabled, the native VLAN traffic is tagged with 802.1Q.
    Allowed VLANs
    This parameter supports a range or comma-separated list of VLANs. Example: 1-3 or 4, 10, 22
    Auto VLAN
    This parameter facilitates automatic assignment of VLANs in cnMatrix switches and access points (APs). When this parameter is enabled, the cnMatrix switches and APs use the Link Layer Discovery Protocol (LLDP) packets to obtain a list of VLANs for automatic assignment.
    Note: Auto VLAN works only with cnMatrix switches and access points (APs). It does not work with any third-party switches and APs. Auto VLAN allows cnMatrix switch to dynamically learn VLANs from an AP. The AP advertises the configured VLANs to the cnMatrix switch. The cnMatrix switch then advertises those VLANs to the uplink NSE 3000 device. This process ensures that VLANs are properly bridged.
    Auto VLAN Message Authentication
    This parameter enables authentication for the LLDP messages where the VLANs are advertised.
    Link Speed Advertisement
    Indicates the port speed that must be configured for advertisement.
    Default: Auto
    • Auto
    • 10 Mbps
    • 100 Mbps
    • 1000 Mbps
    Port Duplex
    Specifies the mode of port communication. The following options are supported:
    • Full Duplex
    • Half Duplex
    Port Speed
    Specifies the port speed.
    Default: Auto
    • Auto
    • 10 Mbps
    • 100 Mbps
    • 1000 Mbps
    Shutdown
    Enables or disables the port.
    VLANs
    Note: You can configure up to 128 VLANs.
    To add a new VLAN, click Add New. The Add New VLAN window appears, as shown in Figure 23.
    To edit an existing VLAN configuration, click the edit icon and modify the parameters in the Edit VLAN window. Finally, click Update to apply the changes.
    VLAN ID
    Indicates the VLAN ID.
    The VLAN ID value can be in the range: 1 to 4094
    Name
    Name of the new VLAN.
    Description
    Displays the user-configured description for the VLAN.
    IP Address
    IPv4 address that is assigned to the VLAN.
    Subnet Mask
    Subnet mask that is assigned to the VLAN.
    Management Access
    Indicates whether the management access is enabled or disabled.
    By default, this parameter is enabled.
    Enable Rate Limit
    Indicates whether the rate limit is enabled or disabled.
    When you select the Enable Rate Limit checkbox, the Rate Limit parameter appears.
    Rate Limit
    Specifies the rate of requests sent or received. This parameter appears only when you enable the Enable Rate Limit parameter.
    This parameter supports only integer values.
    Enable Port Scan
    A scan identifies open ports within a network and helps in detecting potential vulnerabilities that can be exploited by attackers.
    DHCP mode
    Specifies the DHCP mode.
    • None
    • DHCP Server - When you select this option, the DHCP server-related parameters appear.
    • DHCP Relay - When you select this option, the Relay Server IP address parameter appears.
    DHCP Server
    In addition to the below parameters, you must also configure the parameters in the DHCP Options and MAC Binding List sections, as shown in Figure 24.
    Start IP address
    Starting IPv4 address in the range.
    End IP address
    Ending IPv4 address in the range.
    Primary DNS
    The primary DNS server for clients on the network.
    If the DNS server option is enabled on the NSE, the IPv4 address configured for the VLAN can be provided as the DNS server for the network.
    Secondary DNS
    The secondary DNS server for clients on the network.
    Domain
    The DNS search domain for the network.
    Lease Time
    The DHCP lease expiry time for the DHCP pool (in days, hours, and minutes).
    DHCP Options
    NSE allows configuration of standard and custom DHCP options.
    To add a new DHCP option, click Add New. The Add New DHCP Option window appears, as shown in Figure 25.
    To edit an existing DHCP option, click the edit icon and modify the parameters in the Edit DHCP Option window. Finally, click Update to apply the changes.
    Option
    The following DHCP options are supported:
    • Log server(7)
    • Domain name(15)
    • NTP server(42)
    • Vendor specific information(43)
    • Vendor class identifier(60)
    • TFTP server name(66)
    • Boot file name(67)
    • Proxy auto config(252)
    • Custom
    Code
    A value for the code.
    This parameter allows a maximum value of 254.
    Type
    • Text
    • IP Address
    • Integer
    Value
    A value in ASCII.
    MAC Binding List
    For every DHCP pool configured, the user can bind the client MAC address with an IPv4 address from the network. This enables the client to obtain the same IPv4 address whenever they connect to the NSE 3000 device.
    Following parameters are required to create the binding list:
    • MAC address of the client
    • IPv4 address from the configured pool
    When you set MAC and IP address fields and click Add, the binding of MAC and IP address is added.
    Note: Upto 200 MAC to IP address bindings are supported per DHCP pool.
    Note: When you bind, the binding IP address should be outside the DHCP pool range.
    To add a new MAC binding, click Add New. The Add New MAC Binding window appears, as shown in Figure 26.
    To edit an existing MAC binding, click the edit icon and modify the parameters in the Edit MAC Binding window. Finally, click Update to apply the changes.
    MAC
    The MAC address of the client.
    IP Address
    The IPv4 address that must be assigned to the client.
    Description
    Displays the user-configured description.
    Import
    Imports the MAC bindings.
    Note: The CSV file that you import must be in the three-column format, for example, MAC, IP address, and Description.
    To import MAC bindings, click Import. The Import MAC Bindings window appears, as shown in Figure 27.
    Replace existing list
    Indicates whether the imported bindings will overwrite the existing list or append to the list.
    • If enabled, the imported bindings will overwrite the existing list
    • If disabled, the imported bindings will append to the existing list.
    Export
    Exports the configured bindings list.
    • Export all as CSV
    • Export page as CSV
    To export MAC bindings, click Export. The export options appear, as shown in Figure 28.
    DHCP Relay
    Indicates whether the DHCP relay unicasts the DHCP request to an external DHCP server.
    IPv4 address of the external DHCP server.
    Static Routes
    To add a new route, click Add New. The Add New Route window appears, as shown in Figure 29.
    To edit an existing route, click the edit icon and modify the parameters in the Edit Route window. Finally, click Update to apply the changes.
    Destination Network
    The IPv4 address of the destination network.
    Prefix Length
    The prefix length for the network address.
    This parameter supports integer values and a maximum value of 32.
    Next Hop
    The next hop IPv4 address for the route.
    Exit Interface
    The exit interface through which the next hop is reachable.
    Metric
    The metric for the route.
    To add multiple VLANs, click the Add Multiple button. The Add Multiple VLANs window appears, as shown in Figure 30.
    Description
    First VLAN ID
    Indicates the first VLAN ID.
    The supported VLAN ID value range is between 1 and 4094.
    Number of VLANs
    Indicates the number of VLANs that you want to add.
    Subnet
    • IP Address and Netmask - When you select this option, the IP address and Netmask options appear.
    • Hosts per subnet - When you select this option, the First IP Address and Hosts per subnet options appear.
    IP address
    The IPv4 address of the first VLAN.
    Netmask
    The netmask of the subnet.
    First IP Address
    The first IPv4 address of the subnet.
    Hosts per subnet
    The number of hosts that you want for the subnet.
    DHCP mode
    • None
    Lease Time
    DHCP Options
    Option
    • Log server(7)
    • Domain name(15)
    • NTP server(42)
    • Custom
    Code
    Type
    • Text
    • IP Address
    • Integer
    Value
    A value in ASCII.
    DHCP Relay
Figure 22 The Edit Port window
Figure 23 The Add New VLAN window
Figure 24 DHCP Options and MAC Binding List
Figure 25 The Add New DHCP Option window
Figure 26 The Add New MAC Binding window
Figure 27 The Import option in MAC Binding List
Figure 28 The Export option in MAC Binding List
Figure 29 The Add New Route window
Figure 30 The Add Multiple VLANs window
  1. Click Save.
Groups
Using the Groups tab, you can configure user groups, IP groups, and application groups.
To view the Groups page, complete the following steps:
  1. On the NSE Groups > Add New page, select the Groups tab.
    The Groups page appears, as shown in Figure 31.
    Figure 31 The Groups page
  1. Configure the parameters, as described in Table 4.
    Table 4 Parameters on the Groups page
    Parameter Description
    On the Groups page, there are User Groups, IP Groups, and ApplicationGroups sections.
    User Groups
    User groups are used to group locally configured networks and these groups can be used to associate with policies, especially application rules or DNS rules.
    To add a new user group, click Add New. The Add User Group window appears, as shown in Figure 32.
    To edit a user group, click the edit icon and modify the parameters in the Edit User Group window. Finally, click Update to apply the changes.
    Name
    Name for the user group.
    Description
    Description for the user group.
    IP Addresses/Source Subnets
    IPv4 addresses or source subnets for the user group.
    IP Groups
    IP groups are used to group networks originating from the WAN, and can be used to attach port forwarding rules.
    To add a new IP group, click Add New. The Add IP Group window appears, as shown in Figure 33.
    To edit an IP group, click the edit icon and modify the parameters in the Edit IP Group window. Finally, click Update to apply the changes.
    Name
    Name for the IP group.
    Description
    Description for the IP group.
    IP Addresses/IP Ranges/Source Subnets
    IPv4 addresses, IP ranges, or source subnets for the IP group.
    Application Groups
    Application groups are used to group applications by using application names or categories, which can then be attached to a policy for permitting or denying access.
    To add a new application group, click Add New. The Add New Application Group window appears, as shown in Figure 34.
    To edit an application group, click the edit icon and modify the parameters in the Edit Application Group window. Finally, click Update to apply the changes.
    Name
    Name for the application group.
    Description
    Description for the application group.
    Applications
    To add applications to the application group, select the required application(s) from the drop-down list and click Add New. The selected applications are added in the Name list.
    Application Name
    Applications for the new application group.
    Categories
    To include categories for the new application group, select the required categories.
    Categories
    Categories for the new application group.
Figure 32 The Add User Group window
Figure 33 The Add IP Group window
Figure 34 The Add New Application Group window
  1. Click Save.
WAN
Using the WAN tab, you can configure the settings related to the WAN interface.
To configure parameters on the WAN page, complete the following steps:
  1. On the NSE Groups > Add New page, select the WAN tab.
    The WAN page appears.
    Figure 35 The WAN page
  2. Configure the parameters, as described in Table 5.
    Table 5 Parameters on the WAN page
    Parameter
    Description
    On the WAN page, there are WAN Configurations, LoadBalancing, and Flow Preferences sections.
    WAN Configurations
    In this section, you can configure the parameters in Connection Health, Dynamic DNS, Link Capacity, Traffic Shaping, Failover Policy, and WAN Speed Test subsections.
    The same parameters appear in both WAN-1 and WAN-2 tabs.
    Determines the mode of IP address assignment for the WAN interface.
    • Dynamic: Dynamically learn the IP address and DNS from the DHCP server.
    • Static: Manually configure the IP address, gateway, and DNS server IP provided by the service provider.
    • PPPoE: When you configure PPPoE, you must provide the username and password of the service provider. While the account name and service name are not mandatory configurations, they may be required if the service provider enforces it. By default, the MTU is set to 1492 and the TCP MSS clamping is enabled. If required, you can also tag the packet on the WAN link to send.
    Enable 802.1q VLAN tagging of frames
    When this parameter is enabled, 802.1Q tag is inserted with configured VLAN ID for all the packets going out of the WAN interface.
    VLAN ID
    This parameter is applicable only when Enable 802.1q VLAN tagging of frames checkbox is selected.
    VLAN ID range: 1 and 4094.
    When the 802.1Q header is configured, all transmitted frames are expected to include the 802.1Q header with the same VLAN ID.
    Following parameters appear when you select Static from the IP Address Assignment drop-down list.
    IP Address
    The IPv4 address of the WAN interface.
    This parameter appears only when Enable HA checkbox is selected from the Basic screen.
    The IPv4 address of the HA spare.
    Subnet Mask
    The subnet mask for the IPv4 address of the WAN interface.
    Default Gateway
    The IPv4 address of the default gateway for the WAN interface.
    Primary DNS
    The IPv4 address of primary upstream DNS server on this interface.
    Secondary DNS
    The IPv4 address of secondary upstream DNS server on this interface.
    Following parameters appear when you select PPPoE from the IP Address Assignment drop-down list.
    Account Controller Name
    Name of the account controller.
    This parameter is optional.
    Service Name
    Indicates the service name of the Account Controller.
    The service name configuration is optional.
    User
    User name for PPPoE authentication.
    Password
    Password for PPPoE authentication.
    MTU
    MTU for PPPoE interface.
    MTU ranges from 500 to 1492 bytes.
    Default: 1492 bytes.
    TCP MSS Clamping
    Indicates whether TCP MSS Clamping is enabled or disabled.
    Additional IP Addresses
    WAN IP addresses that are available for source NAT.
    Note:The WAN interface supports up to 16 IP addresses.
    Enable Source NAT
    Indicates whether the source NAT is enabled or disabled.
    When enabled, NSE 3000 device will replace the source IP address of the traffic routed from LAN to WAN with the WAN interface IP address.
    Source NAT Rules
    Allows user to configure source NAT rules. User can choose the WAN IP addresses from the Additional IP Address for source NAT. User can configure WAN IP address(es) of their choice for source NAT. By default, all the LAN users' traffic will be source NATed to the configured WAN IP address(es). When LAN pool is configured, the traffic from the specified LAN networks will be source NATed to the configured WAN IP address(es).
    Note: Source NAT Rules supports up to 16 rules per WAN.
    To add a new source NAT, click Add New. The Add New Source NAT Rule window appears, as shown in Figure 36.
    Precedence
    The precedence value for the source NAT rule.
    The precedence value can be between 1 and 150.
    LAN Pool
    • All
    • IP Group
    • IP Address / Source Subnet
    WAN Pool
    • Single IP Address
    • Multiple IP Addresses
    IP Address
    IPv4 address for the WAN pool.
    Applicable only when Single IP Address option is selected.
    Start IP
    Starting IP address in the range.
    This parameter is applicable only when Multiple IP Addresses option is selected.
    End IP
    Ending IP address in the range.
    IP Group
    Select the IP group for the source NAT. IP groups are the ones that you configure in the Groups > IP Groups section.
    This parameter is applicable only when IP Group option is selected.
    This parameter is applicable only when IP Address / Source Subnet option is selected.
    Connection Health
    This section is configured to monitor the WAN connection health.
    Click the editicon to modify the Monitor Host configuration, as shown in Figure 37. Finally, click Update to apply the changes.
    To add a new monitor host, click Add New. The Add New Monitor Host window appears, as shown in Figure 38.
    Monitor Host
    The hosts used to monitor and collect network traffic data.
    Default: 8.8.8.8
    Number of Host Failures
    The number of monitor hosts that fail to declare the link down.
    Default value: 1
    The maximum number of monitor hosts that can be configured to fail is 5.
    Failure Detect Time
    The time period (in seconds) during which the device waits for the response from the monitored host before declaring the link down.
    Default: 5. Range: 5 to 60
    Interval
    The time interval (in seconds) used by the device to check and reach the monitor hosts.
    Default: 2. Range: 2 to 10
    Timeout
    The time period (in seconds) the device waits for a response from the monitor host after which the connection is timed out.
    Default: 2. Range: 1 to 10
    Dynamic DNS
    Enable Dynamic DNS
    Indicates whether the dynamic DNS for the interface is enabled or disabled.
    Following parameters appear when Enable Dynamic DNS checkbox is selected.
    DNS Provider
    • Cloudflare: Requires secret/access token and zone configuration.
      In the Cloudflare account, navigate to Profile > API Tokens to create a token.
      Following is the recommended setting:
      • Permissions: Zone, DNS, Edit
      • ZoneResource: Include, Specific Zone, <zone name>
    • Godaddy: Requires API key, secret/access token, and zone configuration.
      In the Godaddy account, create an API key at https://developer.godaddy.com/keys
    • Hetzner: Requires secret/access token and zone configuration.
      In the Hetzner account, navigate to Profile > API Tokens and create an access token.
    • Namecheap: Requires password and zone configuration.
      1. In the Namecheap account, navigate to Domains > Free DNS to manage external domains.
      2. Before you update/create a record, a new record of type A must exist. To create a record, navigate to the dashboard, and then navigate to Products > Advanced DNS. Add a new record of type A. On the same page, enable Dynamic DNS and note the password.
    • Noip: Requires server name, username, and password configuration.
    • Route53: Requires API key, secret/access token, and zone configuration.
      1. In the Route 53 account, navigate to route53 > Hosted Zones > Create Hosted Zone to create a zone. Use type Public hosted zone. Note the name servers in hosted zone details and the hosted zone ID.
      2. Navigate to IAM > Users > Create user. Select attach policies directly. Create a policy.
      The following is an example of a policy:
      "Version": "2012-10-17",
      "Statement": [
      "Sid": "",
      "Effect": "Allow",
      "Action": [
      "route53:ListResourceRecordSets",
      "route53:GetChange",
      "route53:ChangeResourceRecordSets"
      "Resource": [
      "arn:aws:route53:::hostedzone/<ZONE_ID>",
      "arn:aws:route53:::change/*"
      "Sid": "",
      "Effect": "Allow",
      "Action": [
      "route53:ListHostedZonesByName",
      "route53:ListHostedZones"
      "Resource": "*"
      1. Replace ZONE_ID in the policy with the previously noted zone id. Select the new policy for the previously created user.
      2. To create access key, navigate to users, select the user, Security Credentials > Create Access Key.
    • Porkbun: Requires API key, secret/access token, and zone configuration.
      In the Porkbun account, navigate to Account > API Access to create a token. Additionally, the domain configuration much be changed to enable API access.
    • Dyn: Oracle Dyn requires server name, username, and password configuration.
    • DynDNS2 compliant: Requires server name, username, and password configuration.
    By default, Noip option is selected.
    DNS Hostname
    Indicates the DNS host name.
    Link Capacity
    Uplink
    The WAN uplink capacity in Mbps.
    Default:1000. Range: 1 to 1000
    Downlink
    The WAN downlink capacity in Mbps.
    Traffic Shaping
    Note: Traffic Shaping supports up to 16 rules per WAN.
    To add a new traffic shaping rule, click Add New, the Add New Traffic Shaping Rule window appears, as shown in Figure 39.
    Enable Traffic Shaping
    Indicates whether traffic shaping is enabled or disabled.
    Precedence
    The precedence value for the traffic shaping rule.
    Description
    Displays a user-configured description for the traffic shaping rule.
    Uplink Bandwidth
    Indicates the uplink bandwidth in Mbps.
    Range: 1 to 1000
    Downlink Bandwidth
    Indicates the downlink bandwidth in Mbps
    Range: 1 to 1000
    DSCP
    Differentiated Services Code Point (DSCP) can range from 0 to 63, with 0 being the lowest priority and 63 being the highest priority.
    Type
    Indicates the type of filter rule.
    • IP Based – Allows you to configure Protocol parameter as TCP, UDP, or any.
    • Application Based – Allows you to configure Deep Packet Inspection (DPI) Type parameter as Application or Category.
    This parameter is applicable only when Type parameter is Application Based.
    • Application – Specific type of application within a category.
    • Category – All applications belonging to a category (For example, Social Messaging).
    DPI Application
    This parameter is applicable only when Deep Packet Inspection (DPI) Type parameter is set to Application.
    DPI Category
    This parameter is applicable only when Deep Packet Inspection (DPI) Type parameter is set to Category.
    Protocol
    This parameter is applicable only when Type parameter is IP Based.
    • TCP – Match TCP traffic.
    • UDP – Match UDP traffic.
    • any – Match any of the above protocol traffic.
    Source IP Address
    The source IPv4 address for the shaping rule.
    Mask
    The subnet mask for the shaping rule.
    Port
    Displays the source port from which IPv4 address messaging is sent.
    Destination IP Address
    The destination IPv4 address for the shaping rule.
    Mask
    Port
    Displays the destination port to which IPv4 address messaging is sent.
    Failover Policy
    Note: Failover Policy supports up to 32 rules per WAN.
    To add a new failover policy, click Add New. The Add New Failover Policy window appears, as shown in Figure 40.
    Enable Failover Policy
    Indicates whether failover policy is enabled or disabled.
    Precedence
    The precedence value for the failover policy.
    Description
    A description for the policy.
    Action
    Type
    The type of failover rule.
    • IP Based – Allows you to configure the Protocol parameter as TCP, UDP, or any.
    • Application Based – Allows you to configure Deep Packet Inspection (DPI)Type parameter as Application, Category, or Application Group.
    Protocol
    Source IP Address
    The source IPv4 address for the failover rule.
    Mask
    The subnet mask for the failover rule.
    Port
    The source port for the failover rule.
    The destination IPv4 address for the failover rule.
    Mask
    Port
    Displays the destination port for the failover rule.
    • Application Group - All applications belonging to a group.
    Apply to
    • All
    • User Group
    User Group
    This parameter is applicable when User Group option is selected.
    This parameter is applicable when IP Address / Source Subnet option is selected.
    WAN Speed Test
    Enable WAN Speed Test
    Enable or disable the WAN speed test.
Figure 36 The Add New Source NAT Rule window
Figure 37 The Edit Monitor Host window
Figure 38 The Add New Monitor Host window
Figure 39 The Add New Traffic Shaping Rule window
Figure 40 The Add New Failover Policy window
  1. Expand the Load Balancing section and configure the parameters, as described in Table 6.
    Table 6 Parameters on the Load Balancing section
    Parameter
    Description
    Load Balancing
    WAN-1 Mode
    Determines the load balancing mode of device.
    By default, the WAN-1 Mode parameter is set to Shared.
    • Shared – Enables the WAN link to actively forward a percentage of user traffic. The percentage of user traffic on this link is set via the Traffic Share Percentage parameter.
    • Backup – The WAN link forwards user traffic only when all of the Shared WAN interfaces are down.
    • Disabled – Disables the WAN link from participating in WAN link load sharing, and failover procedures.
    For the Shared mode, the traffic share percentage must be between 5 and 100.
    WAN-2 Mode
    Determines the load balancing adjust mode of device.
    By default, the WAN-2 Mode parameter is set to Backup.
    For the Shared mode, the traffic share percentage between 5 and 100.
  2. Expand the Flow Preferences section and configure the parameters, as described in Table 7.
    Table 7 Parameters on the Flow Preferences section
    Parameter
    Description
    Flow Preferences
    Flow preferences support up to 30 rules for both WANs combined.
    To add a new flow preference, click Add New. The Add New Flow Preference window appears, as shown in Figure 41.
    WAN Interface
    • WAN-1
    • WAN-2
    Description
    Provide a description for the flow preference.
    Policy
    The flow preference policy.
    • Flexible – Allow traffic to failover if the preferred WAN link goes down.
    • Strict – Traffic is dropped in strict mode, if the preferred WAN link goes down.
    Type
    The flow preference type.
    Protocol
    • TCP – Match TCP preference.
    • UDP – Match UDP preference.
    • Any – Match any of the above preferences.
    Source IP Address
    The source IPv4 address for the flow preference.
    Mask
    The subnet mask for the flow preference.
    Port
    The source port for the flow preference.
    The destination IPv4 address for the flow preference.
    Mask
    Port
    The destination port for the flow preference.
    DPI Application
    DPI Category
Figure 41 The Add New Flow Preference window
  1. Click Save.
Firewall
NSE 3000 firewall allows the user to configure the IP-based and application-based outbound rules, GEO IP filters, port forward rules, one-to-one NAT mappings, and one-to-many NAT mappings. All inbound connections are denied by default. You can configure port forwarding or NAT rules to allow inbound traffic. Outbound traffic is allowed by default. Using application-based outbound rules, users can create rules to block websites without specifying IP addresses or port ranges. Application-based rules allow the user to block a specific type of application within a category or all applications belonging to a category (For example, social messaging).
Note
Up to 150 outbound firewall rules are supported for an NSE Group including combinations of IP-based and application-based rules.
To configure parameters on the Firewall page, complete the following steps:
  1. On the NSE Groups > Add New page, select the Firewall tab.
    The Firewall page appears, as shown in Figure 42.
    Figure 42 The Firewall page
  2. Configure the parameters, as described in Table 8.
    Table 8 Parameters on the Firewall page
    Parameter
    Description
    On the Firewall page, there are Inbound Filter Rules, Outbound Filter Rules, Denial of Service (DoS) Protection, GEO IP WAN to LAN Filters, GEO IP LAN to WAN Filters, Port Forward Rules, NAT One-to-One, NAT One-to-Many, and Device Access sections.
    By default, NSE firewall routers are configured to function as stateful firewalls by dropping packets that are not related to an established connection.
    Allow traffic from WAN to LAN
    An option to enable or disable the stateful firewall behavior.
    In special deployment cases, when NSE is positioned behind an MPLS uplink router, you can enable this behavior. To enable this behavior, select the Allow traffic from WAN to LAN checkbox. Additionally, you must disable source NAT on the WAN UI page to allow routing of traffic without NAT, originated on the LAN directed towards the WAN.
    To add a new outbound filter rule, click Add New. The Add New Filter Rule window appears, as shown in Figure 43.
    Precedence
    The precedence value for the filter rule.
    Description
    Displays a user-configured description for the filter rule.
    Action
    Determines the action of filter.
    • Permit - Allow traffic matching this filter rule.
    • Deny - Drop traffic matching this filter rule.
    Type
    The type of filter rule.
    • IP Based – Configure Protocol parameter as TCP, UDPICMP or any.
    • Application Based – Configure Deep Packet Inspection (DPI) Type parameter as Application, Category, or Application Group
    Protocol
    • TCP: Match TCP traffic.
    • UDP: Match UDP traffic.
    • ICMP: Match ICMP traffic.
    • any: Match any of the above protocol traffic.
    Source IP Address
    The source IPv4 address for the filter rule.
    Mask
    The source subnet mask for the filter rule.
    Port
    This parameter is applicable only when Protocol parameter is TCP or UDP.
    Supported values: 1 to 65535 or any
    The destination IPv4 address for the filter rule.
    Mask
    The destination subnet mask for the filter rule.
    Port
    DPI Application
    This parameter is applicable only when DPI Type parameter is set to Application.
    DPI Category
    This parameter is applicable only when DPI Type parameter is set to Category.
    Apply to
    • All
    • User Group
    User Group
    IP Spoof
    Enable or disable the IP spoof attack protection.
    Smurf Attack
    Enable or disable the smurf attack protection.
    IP Spoof Log
    Enable or disable IP spoof log messages.
    ICMP Fragment
    Enable or disable the fragmented ping attack.
    GEO IP WAN to LAN filters allows users to configure rules to permit/deny traffic based on the source country of inbound traffic.
    Mode
    Specifies the mode for GEO IP WAN to LAN filters.
    • Allow Only (Deny by default) – Allow traffic coming from the countries that are configured. The traffic coming from the countries which are not part of the configured countries will be dropped.
    • Deny Only (Allow by default) – Block traffic coming from the countries that are configured. The traffic coming from countries that are not part of the configured countries will be allowed.
    • None – Disables the feature. Traffic is allowed from all the countries.
    Countries
    The source countries from which the traffic originates.
    Exceptions
    Exceptions allow users to configure source IP address ranges that are allowed in the inbound traffic.
    To add a new exception, click Add New. The Add New Exception window appears, as shown in Figure 44.
    Start IP
    End IP
    GEO IP LAN to WAN Filters allows users to configure rules to permit/deny traffic based on the destination country of outbound traffic.
    Mode
    Specifies the mode for GEO IP LAN to WAN filters.
    • Allow Only (Deny by default): Allow traffic destined to the countries matching the configured countries. The traffic destined for the countries which are not part of the configured countries will be dropped.
    • Deny Only (Allow by default): Block traffic destined to the countries matching the configured countries. The traffic destined for the countries which are not part of the configured countries will be allowed
    • None: Disables the feature. Traffic is allowed in all countries.
    Countries
    The destination countries to which the traffic is destined.
    Exceptions
    Exceptions allow users to configure destination IPv4 address ranges that are allowed in the outbound traffic.
    Start IP
    End IP
    Port Forward Rules
    Port Forward Rules allow users to forward traffic destined to the WAN Interface IP address of NSE 3000 on a specific TCP or UDP port to any of the LAN IP address. Port Forward Rules provides remote access to internal resources.
    To add a new port forward rule, click Add New. The Add New Port Forward Rule window appears, as shown in Figure 45.
    WAN
    The interface to forward inbound traffic to the internal host.
    • WAN-1
    • WAN-2
    Description
    Displays the user-configured description for the port forward rule.
    LAN IP Address
    The IPv4 address to which traffic will be forwarded.
    LAN Port
    The LAN port to which the traffic will be forwarded.
    Supported values: 1 to 65535.
    Protocol
    The protocol of forwarded traffic.
    • TCP
    • UDP
    Port
    The destination port of the incoming traffic on the WAN interface.
    Apply To
    • All
    • IP Group
    IP Group
    NAT One-to-One
    NAT One-to-One allows users to map an IP address on the WAN side to a LAN IP address. The IP address on the WAN side should be different from any of the WAN interface (WAN-1/WAN-2) IP addresses. NAT One-to-One rules provide remote access to any of the LAN resources.
    To add a new NAT one-to-one, click Add New. The Add New NAT One-to-One window appears, as shown in Figure 46.
    WAN
    • WAN-1
    • WAN-2
    Public IP Address
    The public IPv4 address on the WAN side that is used to access the LAN resource.
    The public IPv4 address is different from the IPv4 address of the WAN (WAN-1/WAN-2) interfaces.
    LAN IP Address
    The LAN IPv4 address of the server which is hosting the resource.
    Protocol
    The protocol of the incoming traffic.
    • TCP
    • UDP
    NAT One-to-Many
    NAT One-to-Many provides remote access to internal resources. It maps a public IP address to multiple LAN IPs and ports.
    To add a new NAT one-to-many, click Add New, the Add New NAT One-to-Many window appears, as shown in Figure 47.
    WAN
    • WAN-1
    • WAN-2
    Public IP Address
    LAN IP Address
    LAN Port
    The LAN Port which is hosting the resource.
    Protocol
    • TCP
    • UDP
    Port
    Device Access
    Respond to ICMP pings from WAN
    This parameter is disabled by default.
    When enabled, this service is enabled for all the sources, unless specific IP addresses or IP groups are configured in the IP Group and IP Address / Source Subnet parameters.
    IP Group
    Specifies the IP group for this service.
    Specifies the IPv4 address or source subnet for this service.
Figure 43 The Add New Filter Rule window
Figure 44 The Add New Exception window
Figure 45 The Add New Port Forward Rule window
Figure 46 The Add New NAT One-to-One window
Figure 47 The Add New NAT One-to-Many window
  1. Click Save.
DNS
NSE 3000 supports DNS-based filters. DNS-based filters allow users to block certain category of websites. From the blocked list, users can still allow certain websites by adding them to the exception list. For example, if user blocks social-media category then all the social websites will be blocked including linkedin.com since linkedin.com belongs to social-media category. Adding linkedin.com to the Exception to filters list will allow access to linkedin.com while blocking other social-media websites.
To configure parameters on the DNS page, complete the following steps:
  1. On the NSE Groups > Add New page, select the DNS tab.
    The DNS page appears, as shown in Figure 48.
    Figure 48 The DNS page
  2. Configure the parameters, as described in Table 9.
    Table 9 Parameters on the DNS page
    Parameter
    Description
    On the DNS page, there are DNS, Policies, and Hosts sections.
    DNS
    Enable Built-in DNS Server
    Indicates whether the on-board DNS server is enabled or disabled.
    Block external DNS servers
    Blocks the client to reach to any external DNS servers.
    Block external DNS exceptions
    Allows the clients added in the exceptions list to reach to any external DNS servers.
    Log to Syslog
    Specifies whether the DNS queries received from the client is logged to an external syslog server.
    Learn DNS servers from DHCP
    Dynamically learns the DNS server IP on WAN.
    When you disable this parameter, the Primary DNS and Secondary DNS parameters are displayed.
    Primary DNS
    The IPv4 address of the primary upstream DNS server.
    Secondary DNS
    The IPv4 address of the secondary upstream DNS server.
    Local DNS Entries
    To add a new local host, click Add New. The Add New Local Host window appears, as shown in Figure 49.
    Domain
    A domain name for the local host.
    IP address
    The IPv4 address of the local host.
    Conditional Forwarding Rules
    To add a new forwarding rule, click Add New. The Add New Forwarding Rule window appears, as shown in Figure 50.
    Domain
    A domain name for the forwarding rule.
    IP address
    The IPv4 address of the server to which the DNS query is forwarded.
    DNS Filter Mode
    Specifies the mode for DNS filtering. The following options are supported:
    • Disabled: Disables DNS filter. By default, this option is selected.
    • Learning: Builds local cache for domain categories but does not filter requests.
    • Filtering: Filters requests based on configuration.
    Policies
    To add a new policy, click Add New. The Add New Policy window appears, as shown in Figure 51.
    Name
    Name for the policy.
    Description
    Description about the policy.
    Deny categories
    Categories to deny in the following sections:
    • Productivity
    • Privacy
    • Sensitive
    • Misc
    • IT Resources
    • Security
    Expand the sections and select individual categories. To select all categories in a section, select the checkbox provided for the section.
    Safe Search Mode
    • Disabled: Disables safe search mode. By default, this option is enabled.
    • Moderate: Enable moderate safe search mode.
    • Restricted: Enable restricted safe search mode.
    Allow Exceptions (List of Domain Names)
    Enter the exempted domain names separated by a comma (,).
    Apply to
    • All: Apply to all user groups. By default, this option is selected.
    • User Group: Apply to selected user groups.
    User Group
    This parameter is applicable only when User Group option is selected for Apply to parameter.
    Hosts
    Hosts section contains two tabs - Safe Search Moderate Hosts and Safe Search Restricted Hosts
    The following parameters appear in both the tabs and can be configured as required.
    A list of hosts are already added by default. You can modify these hosts by clicking the edit icon or you can add new hosts by clicking Add New in the respective tabs as shown in Figure 52 and Figure 53.
    Domain Name
    The domain name for the safe search host
    IP address
    The IPv4 address of the safe search host.
Figure 49 The Add New Local Host window
Figure 50 The Add New Forwarding Rule window
Figure 51 The Add New Policy window
Figure 52 The Add New Safe Search Moderate Host
Figure 53 The Add New Safe Search Restricted Host
  1. Click Save.
Threat Protection
Using the Threat Protection tab, you can configure the Intrusion Detection and Prevention system (IDS/IPS) parameters.
NSE 3000 supports IDS/IPS engine. IPS engine uses a series of rules that help define a malicious network activity. IPS engine supports rules from snort and emerging threats. The solution supports both community and licensed rules. The IPS engine uses these rules to find packets that match against them and generates alerts for users.
To configure parameters on the Threat Protection page, complete the following steps:
  1. On the NSE Groups > Add New page, select the Threat Protection tab.
    The Threat Protection page appears, as shown in Figure 54.
    Figure 54 The Threat Protection page
  2. Configure the parameters, as described in Table 10.
    Table 10 Parameters on the Threat Protection page
    Parameter
    Description
    IDS/IPS
    Enable IDS/IPS
    Indicates whether IDS/IPS is enabled or disabled.
    By default, this parameter is enabled only in new NSE groups.
    When this parameter is enabled, the following default settings apply:
    • Mode: Detection
    • Rule Type: snort-community
    • Rules: Balanced
    • Auto Update: Enabled
    • Auto Update Interval: 24 Hrs
    Mode
    Specifies the IDS/IPS mode.
    • Detection – Detects malicious activity and generates alerts for users.
    • Prevention – Detects malicious activity, generates alerts for users, and takes action to prevent attacks.
    Rule Type
    Specifies the IDS/IPS rule type.
    • snort-community – The community rule set is a GPLv2 Talos certified rule set that is distributed free of charge and without any license restrictions. The rules are updated every Tuesday and Thursday.
    • snort-vrt – The Snort Subscriber rule set is developed by Talos research team and is governed by license agreement. The rule set is updated on Tuesday and Thursday. The snort-vrt rule set requires an oinkcode to download and activate rules.
    • emerging-threats open – Consists of signatures contributed from the community. The emerging-threats open rule sets are distributed free of charge.
    • emerging-threats pro – Consists of signatures created as a result of Proofpoint research. The rule sets are governed by license agreement. The emerging-threats pro rule set requires an oinkcode to download and activate the rules.
    Rules
    Specifies the IDS/IPS rule policy. This parameter is applicable when Rule Type is snort-vrt or snort-community.
    • Connectivity – Policy designed to favor device performance over the security controls in the policy.
    • Balanced – This policy is the default policy that is recommended for initial deployments. The policy attempts to balance security needs and performance characteristics.
    • Security – This policy is designed for customer base that is extremely concerned about organizational security. This policy is deployed in networks that have higher security requirements.
    Oink Code
    This parameter is applicable when Rule Type is snort-vrt or emergency- threats pro.
    Category
    Categories to select from the Category section. This parameter is applicable when Rule Type is snort-vrt, emerging-threats open, or emerging-threats pro.
    Note:
    The categories are same for emerging-threats open and emerging-threats pro rule types.
    You can select or clear all categories by using the Category checkbox.
    Rule Updates
    Auto Update
    Indicates whether the IDS/IPS rules must be automatically updated or not.
    When Auto Update is enabled, NSE 3000 will periodically download and activate the IDS/IPS rules.
    Time interval for the periodic updates of IDS/IPS rules.
    • 12 Hrs – Auto updates the rules every 12 hours.
    • 24 Hrs – Auto updates the rules every 24 hours.
    By default, the 24 Hrs option is selected.
    IDS/IPS bypass list
    List of allowed IPv4 addresses or range of allowed IPv4 addresses.
    IDS/IPS operating in prevention mode blocks traffic from a host on detecting malicious traffic from the host.
    When an IPv4 address is part of allowed IP addresses, IDS/IPS will not block traffic from the host even when malicious traffic is detected.
  1. Click Save.
VPN
NSE 3000 provides an on-board VPN server that allows remote users to establish a connection using the native VPN client supported in most of the operating systems. The VPN server uses the L2TP/IPsec protocol with the IPsec encryption and hashing algorithms. The VPN server maintains a pool of IP addresses and leases the IP addresses from this pool for remote users.
NSE 3000 also provides an on-board RADIUS server that allows authentication and accounting of enterprise and remote users. The RADIUS server maintains user profiles in a central database.
Using the VPN tab, you can configure DNS server, VPN server, and RADIUS server parameters.
To configure parameters on the VPN page, complete the following steps:
  1. On the NSE Groups > Add New page, select the VPN tab.
    The VPN page appears, as shown in Figure 55.
    Figure 55 The VPN page
  2. Configure the parameters, as described in Table 11.
    Table 11 Parameters on the VPN page
    Parameter
    Description
    On the VPN page, there are Site-to-Site VPN, Client VPN, Users, RADIUSClients, and VPN sections.
    Site-to-Site VPN
    IPsec tunnel is a VPN technology that provides a secure, encrypted connection between two devices or networks over the internet or another public network. It uses IPsec protocols to encrypt the traffic between two endpoints, making it difficult for anyone to intercept the communication.
    IPsec site-to-site tunnel is used to connect two remote sites for secure communications. NSE allows setting up tunnels both in responder mode and initiator mode. Both, IKEv1 and IKEv2 are supported in the configuration. The default version is IKEv2.
    Note: You can configure up to 100 IPsec tunnels.
    Pre-shared key is the authentication method supported by the device. Each site can have its own pre-shared key. The site is identified by an identifier (string or the IP address of the site). Each site has to be configured with a local and remote site for the tunnel to establish.
    To view the IPsec tunnel stats, navigate to the NSE Group > Network > VPN Sites tab, as shown in Figure 57.
    To add a new site-to-site VPN, click Add New. The Add New Site-to-Site VPN window appears, as shown in Figure 56.
    Enable Site-to-Site VPN
    Indicates whether site-to-site VPN is enabled or disabled.
    Following parameters appear when you select Enable Site-to-Site VPN checkbox.
    Name
    A name for the new site-to-site VPN.
    IKE version
    The Internet Key Exchange (IKE) version for the site-to-site VPN. The following options are supported:
    • IKE v1
    • IKE v2
    Role
    Specifies the role for the tunnels. The following options are supported:
    • Initiator
    • Responder
    Default role: Responder
    Dead peer detection interval
    The interval (in seconds) for detecting dead peers.
    Range: 30 - 600 seconds. Default: 120 seconds
    Remote ID
    The remote ID.
    The value of 192.168.50.10 is pre-configured and is not modifiable.
    Local ID
    The local ID.
    Local Subnets
    The comma-separated list of local subnets.
    Remote Subnets
    The comma-separated list of remote subnets.
    Remote PSK
    The remote PSK.
    Local PSK
    The local PSK.
    The following parameters are common for both IKE Phase 1 and IKE Phase 2.
    Encryption
    • aes128
    • aes192
    • aes256
    • aes128-gcm16
    • aes192-gcm16
    • aes256-gcm16
    • 3des
    Integrity
    • md5
    • sha1
    • sha256
    DH Group
    • 1
    • 2
    • 5
    • 14
    • 15
    Key Lifetime
    The duration (in hours) for the pre-shared key.
    Range: 1 to 24
    Client VPN: This section contains the following tabs:
    WireGuard: A VPN protocol that is highly secure.It is simpler and more efficient than traditional IPSec.
    Enable WireGuard
    Indicates whether WireGuard is enabled or disabled.
    Following parameters appear when you select Enable WireGuard checkbox.
    Port
    Indicates the WireGuard listen port number.
    Default: 51820
    Client Pool
    Indicates the WireGuard interface IP for the device and the client IPs to be assigned for the WireGuard clients.
    Keep Alive
    Periodic keep alive packets sent for the configured duration.
    Default: 5 seconds
    Enable Split Tunnel
    Indicates whether the split tunnel is enabled or disabled.
    Note: When you enable split tunnel, only the traffic destined to tunnelled subnets is allowed. You can override the Enable Split Tunnel parameter at the user level.
    Tunnelled Subnets
    Specifies the list of local subnets in NSE that should be allowed access from the WireGuard clients.
    Note: The same Tunnelled Subnets field is auto-populated in the Add New User window. You can edit this field at the user level.
    IPSec IKEV2
    Enable IPSec IKEV2
    Indicates whether IPSec IKEV2 is enabled or disabled.
    Following parameters appear when you select Enable IPSec IKEV2 checkbox.
    Client IP Pool Range Start
    Client IP Pool Range End
    L2TP over IPSec
    Enable L2TP over IPSec
    Indicates whether L2TP over IPSec is enabled or disabled.
    Following parameters appear when you select Enable L2TP over IPSec checkbox.
    IPsec Shared Secret
    Enter a pre-shared key string for the IPsec protocol. The shared secret is used between the VPN Client and Server for device authentication.
    Enable 2FA
    Indicates whether two-factor authentication (2FA) is enabled or disabled.
    VPN Two-Factor Authentication
    1. When you enable two-factor authentication (2FA), scan the QR code to add a 16-digit key to a particular user's Google Authenticator app.
    2. An email is also sent to the configured email address with the QR code and the 16-digit key.
    3. The two-factor authentication gets enabled for the user when the user tries to connect to the NSE 3000 device using the remote VPN client from the WAN side. Users on the LAN side do not require two-factor authentication.
    Users: This section is common for all the three protocols - WireGuard, IPSec IKEV2, and L2TP over IPSec.
    To add a new user, click Add New. The Add New User window appears, as shown in Figure 58.
    Email ID
    Email ID of the user.
    User is either an enterprise user or a remote user.
    Password
    Password for the user.
    Enable WireGuard
    Following parameters appear when Enable WireGuard checkbox is selected in the Add New User window.
    Enable Split Tunnel
    Indicates whether split tunnel is enabled or disabled.
    Tunnelled Subnets
    Device
    Indicates the NSE 3000 device.
    When you select an NSE 3000 device, the device's public key is populated in the[Peer]section of the WireGuard client configuration file.
    WAN Interface
    WAN Interface of the NSE 3000 device.
    When you select a WAN interface, the NSE 3000 device's WAN IP is populated as the endpoint IP in the [Peer] section of the WireGuard client configuration file.
    The following WAN Interface options are supported:
    • WAN-1
    • WAN-2
    Clients: In this section, you have an option to add a new WireGuard client.
    To add a new WireGuard client, click Add New. The Add New WireGuard Client window appears, as shown in Figure 59.
    Name
    Name for the new WireGuard client.
    Auto generate key pair
    Generates a public and private key pair for the client. By default, this parameter is enabled.
    When this option is enabled, the Client Public Key field is auto-populated with the public key generated for that client.
    When this option is disabled, you need to provide the WireGuard client public key generated on the WireGuard client device.
    Client Public Key
    Public key of the client.
    IP Address
    Auto-generated IP address of the WireGuard client.
    Note: You have options to download QR code and configuration file in the Add New WireGuard Client window, as shown in Figure 59.
    RADIUS Clients
    To add a new RADIUS client, click Add New. The Add New RADIUS Client window appears, as shown in Figure 60.
    Name
    Name of the RADIUS client.
    Secret
    The shared secret of the RADIUS client. This is the shared secret (password) that the NAS needs to communicate with the RADIUS server.
    Address
    The IPv4 address or network address of the RADIUS client.
    Prefix Length
    The client network prefix length.
    VPN
    VPN Server Interface
    • WAN-1 - The first WAN interface on your server.
    • WAN-2 - The second WAN interface on your server.
    • All - Applies to all WAN interfaces.
Figure 56 The Add New Site-to-Site VPN window
Figure 57 The VPN Sites page
Figure 58 The Add New User window
Figure 59 The Add New WireGuard client window
Figure 60 The Add New RADIUS Client window
  1. Click Save.
User-Defined Overrides
Using the User-Defined Overrides tab, you can configure the user-defined overrides.
To configure parameters on the User-Defined Overrides page, complete the following steps:
  1. On the NSE Groups > Add New page, select the User-Defined Overrides tab.
    The User-Defined Overrides page appears, as shown in Figure 61.
    Figure 61 The User-Defined Overrides page
  2. In the text box, enter the configuration that you want to apply to the device.
  3. Click Save.
Configuring WAN in the device UI
In the WAN page, you can configure the device’s IPv4 address based on the IP mode.
Note
If PPPoE is used as the WAN connection mode as shown in Figure 62, make sure to configure the PPPoE username and password. Once you have configured the PPPoE user name and password, you can proceed to configure the NSE group by providing the same username and password and then attaching the default NSE group to the device.
Figure 62 PPPoE as WAN connection mode
To view and configure the WAN settings, complete the following steps in the device UI:
  1. From the main NSE 3000 dashboard page, click WAN tab from the left panel.
    The WAN page appears, as shown in Figure 63.
    Note
    By default, WAN-1 page appears. You can configure WAN on WAN-1 or WAN-2.
Figure 63 The WAN page
  1. Configure the parameters, as described in Table 12.
    Table 12 Parameters on the WAN page
    Parameter
    Description
    IP Mode
    Determines the network that must be configured to use IPv4 addresses.
    • Dynamic
    • Static
    • PPPoE
    By default, the Dynamic mode is selected.
    VLAN ID
    The VLAN ID can range from 1 to 4094.
    The VLAN configuration is optional.
    Following parameters appear only when you select the mode as Static from the IP Mode drop-down list, as shown in Figure 64.
    IP Address
    The 32-bit binary number that identifies a network element by both network and host.
    Subnet Mask
    The subnet mask for the destination IP/network for the route.
    Gateway
    The gateway for the destination IP/network for the route.
    DNS
    Primary DNS
    The IPv4 address of primary upstream DNS server.
    Secondary DNS
    The IPv4 address of secondary upstream DNS server.
    Following parameters appear only when you select the mode parameter as PPPoE from the IP Mode drop-down list, as shown in Figure 65.
    Account Name
    The name of Access Controller.
    Service Name
    Service name of Access Controller.
    User Name
    A user name for PPPoE authentication.
    This parameter is mandatory.
    Password
    A password for PPPoE authentication.
    MTU
    MTU for PPPoE interface in bytes.
    Default: 1492. Range: 500 to 1492
    TCP MSS Clamping
Figure 64 Static mode
Figure 65 PPPoE mode
  1. Click Save.
